prs1749
Jul 2, 2018 05:39 UTC
the registry refers to a nonexistent java runtime environment installation or the runtime is corrupted
Posted on July 02, 2018 at 07:39
When I try to run STM32CubeMX.exe, The message 'the registry refers to a nonexistent java runtime environment installation or the runtime is corrupted' appears.  I use Windows 7 PRO and Java is up to date.
    Jeff Tenney
    Senior
    Aug 9, 2018 21:32 UTC
    Same here.
    Aug 9, 2018 21:40 UTC
    Yeah several reports in general on the forum. Here on the old forum https://st-microelectronics.jiveon.com/search.jspa?q=%22nonexistent%20java%20runtime%20environment%22
    Would recommend using the Java tools to see how many other versions of Java are littering the system and remove any of the old clutter.
    Aug 9, 2018 21:48 UTC
    Check this thread, and check what the Java Control Panel reports, Mohamed Monsouri would be the ST Employee to seek out.
    https://st-microelectronics.jiveon.com/message/201737-not-able-to-run-stm32cubemx-tool
    Jeff Tenney
    Senior
    Aug 9, 2018 22:03 UTC
    Thank you Clive!
    I uninstalled Java, then re-installed it. CubeMX is running for me now.
