dspark
The code is not generated properly.
  • February 12, 2018
  • 1036 views
Posted on February 12, 2018 at 01:08
I have an issue when generate code using STM32CubeMX.
At first, it worked properly.
The generated code was fine.
But I changed the Project Settings from HAL driver to LL driver then the code is not generated properly.
The screenshot below is a proect file(EWARM) created with STM32CubeMX.
So, how can I solve the problem?
Thank you.
    Bogdan Golab
    Lead
    February 12, 2018
    Posted on February 12, 2018 at 07:46
    To report a bug (and to reproduce the issue) you need to share:
    -CubeMX version (probably can be concluded from ioc file but it noce to have it anyway)
    -ioc project file (before the change from HAL to LL)
    -the information what driver was switched to LL (RCC, GPIO, etc)
    dspark
    dsparkAuthor
    Posted on February 12, 2018 at 09:23
    Thank you for your reply.
    I checked again this issue, there is no problem.
    I'm really sorry.
