TFT 16bit connections
Hello Everyone
I want connect stm32F LCd controller to TFT lcd but 16 bit  because I have lack of pins . how should I connect the RGB pins of STM32 to RGB pins of the LCD ?
In case I use the LTDC contrller in 16bits , Can I use the unused pins  RGB of the controller  for other  fucntions ?
Thank you in advanced
mƎALLEm
mƎALLEmBest answer
Which STM32 part number?
Please review the tips on how to post a thread in this community: https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228.
You can refer to that application note: https://www.st.com/resource/en/application_note/an4861-introduction-to-lcdtft-display-controller-ltdc-on-stm32-mcus-stmicroelectronics.pdf
Yes.
mƎALLEm
mƎALLEmBest answer
Yes.
August 23, 2024
Hello
We use STM32F429, and STM32UF9
Sami
mƎALLEm
Ok. edited the post then .. PS: There is no STM32UF9 part number.
As said review the application note AN4861.
