Adam BERLINGER
Teams connection issues (error AADSTS50020)
  • March 23, 2021
  • 0 replies
  • 1582 views
it seems that some attendees have issues with logging to the Teams meeting and they receive following error message:
AADSTS50020: User account '<user_email>' from identity provider 'live.com' does not exist in tenant '<STMicroelectronics or other organization>' and cannot access the application '5e3ce6c0-2b1f-4285-8d4b-75ee78787346'(Microsoft Teams Web Client) in that tenant. The account needs to be added as an external user in the tenant first. Sign out and sign in again with a different Azure Active Directory user account.
The problem seems to be somehow related to the login process and perhaps some previous invitations.
The solution could be to:
  1. Go to microsoft.com, logout and login again, then follow the link
  2. Open the link in the incognito mode of the browser (this should be quite reliable)
UPDATE: Note that if you don't have Microsoft/Teams account, you should be able to join without registration as a guest.
Please let us know if you faced this issue, and if the proposed workaround worked.
Best regards,
Adam Berlinger
