MGree.11
Jan 24, 2020 11:47 PM UTC
SWD programming / debug interface on the STM32L073 - SWO??
The STM32 STM32L0x3 ref manual (RM073) and STM32L073 datasheet both show only 2 pins for the SWD programming interface:
- PA13 (SWDIO)
- PA14 (SWCLK)
But the schematic for the STM32L073 Nucelo PCB shows PB3 connected as SWO.
I dont see any reference to PB3 being part of the debug interface in the STM32L073 reference manual, datasheet or Cube MX configuration software.
Is PB3 part of the debug interface or not?
Please advise.
Jan 24, 2020 11:50 PM UTC
NOT supported on CM0(+) devices, board used for several parts.
Jan 24, 2020 11:55 PM UTC
The "Debug Communications Channel" can be implemented via an "Event Recorder" method
https://www.keil.com/pack/doc/compiler/EventRecorder/html/er_use.html
https://www.keil.com/pack/doc/compiler/RetargetIO/html/_retarget__examples_er.html
ST has a free license for Keil on CM0(+) devices
MGree.11
MGree.11Author
Jan 25, 2020 12:05 AM UTC
Hi Clive, So I only need to connect power, ground, PA13, PA14 & Reset for programming and debug? Thanks, Mark. Get Outlook for Android<>
