Uwe Bonnes
Chief
March 6, 2015
SWD clock restrictions
  • March 6, 2015
  • 3 replies
  • 1585 views
Posted on March 06, 2015 at 11:33
the STM32 datasheets do not mention any restictions on SWD or JTAG frequency. Some ''internet knowledge'' tells that older ARM cores had a HCLK/6 limitation on SWD/JTAG clock frequency. Has anybody hard facts for Cortex-M and/or STM32?
#swclk-limits
    March 6, 2015
    Posted on March 06, 2015 at 11:54
    You'd need something pretty exotic to drive it. You might want to ask on an ARM silicon leaning forum. The pins top out at 100 MHz, I'd expect 40-50 MHz to be possible.
    http://www.keil.com/ulinkpro/
    http://www.arm.com/products/system-ip/debug-trace/coresight-soc-components/serial-wire-debug.php
    Uwe Bonnes
    Chief
    March 6, 2015
    Posted on March 06, 2015 at 12:43
    So you postulate that there is no miminum relation between HCLK and SWCLK?
    March 6, 2015
    Posted on March 06, 2015 at 14:52
    You'd want to find yourself someone familiar with the debug unit implementation, either at ARM or ST, start by pushing in via an FAE.
    I'd expect there to be a synchronizer somewhere, which will likely limit you to some fraction of the primary clock, that you're not synchronous with. The logic involved in the shifting is almost certainly capable of >200MHz in an F4.
    I don't think it would be that hard to determine where the gears start grinding.
