STWINK1B connection to a different cloud-based MQTT broker
Is it possible to connect the STWINK1B to a different cloud-based MQTT broker (personal AWS account for example)? If so, can you advise on how this can be done?
Is it possible to attach the STWINK1B on the nRF Cloud which is also on AWS?
Finally, is it possible to externally connect and subscribe via MQTT to the dsh-predmnt that has a STWINK1B device added, using the supplied certificates from your platform?
Thanks,
Darryl
