ASSAAD.ASSAAD
Aug 20, 2018 4:18 PM UTC
structures
Hello All , I am sorry it might be the wrong forum ,
i use STM32f429 with TFT to create a menu system
I am declare a structures for menu but i dont have success to put a structure in side a struture
could me what is wrong ?
 struct menu_type
char  *title;
unsigned char type;
uint16_t  rec_xpos;
uint16_t  rec_ypos;
uint16_t  rec_width;
uint16_t  rec_high;
unsigned int num_items ;
char* items [ 100] ;
void (*nag_ok)();
void (*nag_right)();
void (*nag_left)();
void (*command)();
struct menu_main
struct menu_type submenus;
how can I pass the variables to menu_main ?
Thank you all
    David Littell
    Senior II
    Aug 20, 2018 5:48 PM UTC
    Yes, this is definitely the wrong forum. I'd suggest an introduction-to-C-programming forum to learn the basics of the language.
    Aug 20, 2018 6:27 PM UTC
    Not even sure what the question is actually asking.
    How do you initialize said structure? Is that what you're asking?
    Or how to assign values?
    foo.submenus.title = "Some Title";
    I prefer to use "typedef struct _xyz {} xyz;" form.
