strange problem with keil uvision 5 and interrupts
Posted on December 06, 2014 at 23:52
hello ,
first of all sorry for my bad english. I have problem with isr on keil uvision 5. Simple exception handler, for instance handler for systick interrupt defined as: void SysTick_Handler(){ ....code... } does not working. When debugint it goes to startup_stm32f4xx.s and there stays in infinte loop.(B.) why is it not overriden with code in main.c? best regards, Andjelko. #keil-uvision-5-interrupt #keil-uvision-5-interrupt #keil-uvision-5-interrupt #keil-uvision-5-interrupt
