Storing variables in flash [HAL]
Posted on September 18, 2015 at 14:01
Hello there,
Does the HAL library supports storing variables in the flash memory? In AVR, with a certain macro added to the variable, I could tell the compiler that it should be stored in flash instead of sram and it was not erased between power cycles. I would apreciate all help here. #flash #stm32
