Soumyajit Das
Mar 14, 2017 6:19 AM UTC
STOP2 mode not Entering from HAL_PWREx_EnterSTOP2Mode
Posted on March 14, 2017 at 07:19
MCU: STM32L443VCT
I am calling 'HAL_PWREx_EnterSTOP2Mode(PWR_STOPENTRY_WFI);' from the main application of my code but it seems that the function returns immediately (MCU not entering STOP2 mode). What I might be doing wrong, or where should I look for issues? Am I missing something. Do I need to do any sort of configuration so that the MCU enters STOP2 mode?
I know that I have not configured any wakeup event, but initially I am just trying to make sure that the MCU enters the STOP2 mode
My program flows as follows: (SystemClock_Config is the only function called before calling HAL_PWREx_EnterSTOP2Mode)
void
SystemClock_Config(
void
RCC_OscInitTypeDef
RCC_OscInitStruct;
RCC_ClkInitTypeDef
RCC_ClkInitStruct;
RCC_PeriphCLKInitTypeDef
PeriphClkInit;
RCC_OscInitStruct.
OscillatorType
= RCC_OSCILLATORTYPE_MSI;
RCC_OscInitStruct.
MSIState
= RCC_MSI_ON;
RCC_OscInitStruct.
MSICalibrationValue
= 0;
RCC_OscInitStruct.
MSIClockRange
= RCC_MSIRANGE_6;
RCC_OscInitStruct.
PLL
PLLState
= RCC_PLL_ON;
RCC_OscInitStruct.
PLL
PLLSource
= RCC_PLLSOURCE_MSI;
RCC_OscInitStruct.
PLL
PLLM
= 1;
RCC_OscInitStruct.
PLL
PLLN
= 40;
RCC_OscInitStruct.
PLL
PLLP
= RCC_PLLP_DIV7;
RCC_OscInitStruct.
PLL
PLLQ
= RCC_PLLQ_DIV2;
RCC_OscInitStruct.
PLL
PLLR
= RCC_PLLR_DIV2;
if
(HAL_RCC_OscConfig(&RCC_OscInitStruct) !=
HAL_OK
Error_Handler();
RCC_ClkInitStruct.
ClockType
= RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
RCC_ClkInitStruct.
SYSCLKSource
= RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.
AHBCLKDivider
= RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.
APB1CLKDivider
= RCC_HCLK_DIV1;
RCC_ClkInitStruct.
APB2CLKDivider
= RCC_HCLK_DIV1;
if
(HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) !=
HAL_OK
Error_Handler();
PeriphClkInit.
PeriphClockSelection
= RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_USART2
|RCC_PERIPHCLK_USART3|RCC_PERIPHCLK_LPUART1
|RCC_PERIPHCLK_I2C1|RCC_PERIPHCLK_SDMMC1
|RCC_PERIPHCLK_RNG|RCC_PERIPHCLK_ADC;
PeriphClkInit.
Usart1ClockSelection
= RCC_USART1CLKSOURCE_PCLK2;
PeriphClkInit.
Usart2ClockSelection
= RCC_USART2CLKSOURCE_PCLK1;
PeriphClkInit.
Usart3ClockSelection
= RCC_USART3CLKSOURCE_PCLK1;
* WARNING: Lpuart1ClockSelection have been changed from
* RCC_LPUART1CLKSOURCE_PCLK1 to RCC_LPUART1CLKSOURCE_HSI.
* This will result into feeding 16 MHz clock into LP UART
* instead of 80 MHz clock. Hence, effective clock frequency
* will be 5 (80 / 16) times slower than original frequency.
PeriphClkInit.
= RCC_LPUART1CLKSOURCE_PCLK1;
//RCC_LPUART1CLKSOURCE_HSI;//RCC_LPUART1CLKSOURCE_PCLK1;
PeriphClkInit.
I2c1ClockSelection
= RCC_I2C1CLKSOURCE_PCLK1;
PeriphClkInit.
AdcClockSelection
= RCC_ADCCLKSOURCE_PLLSAI1;
PeriphClkInit.
RngClockSelection
= RCC_RNGCLKSOURCE_PLLSAI1;
PeriphClkInit.
Sdmmc1ClockSelection
= RCC_SDMMC1CLKSOURCE_PLLSAI1;
PeriphClkInit.
PLLSAI1
PLLSAI1Source
PeriphClkInit.
PLLSAI1
PLLSAI1M
= 1;
PeriphClkInit.
PLLSAI1
PLLSAI1N
= 16;
PeriphClkInit.
PLLSAI1
PLLSAI1P
= RCC_PLLP_DIV7;
PeriphClkInit.
PLLSAI1
PLLSAI1Q
= RCC_PLLQ_DIV2;
PeriphClkInit.
PLLSAI1
PLLSAI1R
= RCC_PLLR_DIV2;
PeriphClkInit.
PLLSAI1
PLLSAI1ClockOut
= RCC_PLLSAI1_48M2CLK|RCC_PLLSAI1_ADC1CLK;
if
(HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) !=
HAL_OK
Error_Handler();
__HAL_RCC_PWR_CLK_ENABLE();
if
(HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) !=
HAL_OK
Error_Handler();
HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
/* SysTick_IRQn interrupt configuration */
HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
#sleep-wakeup #stop2 #stm32
Soumyajit Das
Soumyajit DasBest answer
Mar 15, 2017 9:59 AM UTC
Posted on March 15, 2017 at 09:59
Hi Schaltegger Fabian,
  I figured out my issue. I was keeping the JTAG programmer (ST-Link) connected which was blocking the MCU from entering STOP2 mode. Now, after program download to MCU is over, I am disconnecting the JTAG connector & then power cycling the board. Everything seems to work fine!
scag
Mar 15, 2017 6:52 AM UTC
Posted on March 15, 2017 at 07:52
Hi, I had the same problem with my STM32L476RG
Try to disable the Systick timer. If any IRQ is pending, the core does not enter stop2 mode.
Good luck
Soumyajit Das
Soumyajit DasAuthorBest answer
