User.55
December 3, 2018
stmf429ZI Can't use the PA0 as a user button
  • December 3, 2018
  • 1 reply
  • 632 views
I use cubemx set the PA0 as a GPIO input, However it just didn't work. why???
    waclawek.jan
    Maybe because of hardware connection, bad solder joints, or simply improper usage.
    Read out and check the relevant GPIOA registers (MODER mainly); if set properly, check if changing input level on the PA0 pin is reflected in bit 0 of GPIOA_INR.
