joesoftware
Oct 31, 2012 7:26 PM UTC
STM32vldiscovery and hd44780 display
Posted on October 31, 2012 at 20:26
Hi, i tried to use IAR example about LCD for use my display hd44780.
I connected 6 pin (RS,E,DB4,DB5,DB6,DB7) for use it on 4bit configuration (i'm sure that the connection is good cause i used that on my old arduino board).
I only see first line of black simple, nothing else.
Can someone help me with that code or link some other library that work good on stm32vldiscovery.
Thx
    orn
    Oct 31, 2012 10:21 PM UTC
    Posted on October 31, 2012 at 23:21
    I am writing the driver for the same LCD,
    as soon as I finish them i will public them, in this topic you can find an example:
    check it out
    [DEAD LINK /public/STe2ecommunities/mcu/Lists/STM32Discovery/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/STM32Discovery/LCD on STM32F4 Discovery&FolderCTID=0x01200200770978C69A1141439FE559EB459D75800084C20D8867EAD444A5987D47BE638E0F&currentviews=233]https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Discovery/Flat.aspx?RootFolder=%2fpublic%2fSTe2ecommunities%2fmcu%2fLists%2fSTM32Discovery%2fLCD%20on%20STM32F4%20Discovery&FolderCTID=0x01200200770978C69A1141439FE559EB459D75800084C20D8867EAD444A5987D47BE638E0F&currentviews=233
    joesoftware
    Oct 31, 2012 10:46 PM UTC
    Posted on October 31, 2012 at 23:46
    thx, while i wait ur release i do some try to modify other code, when u have done please update this topic.
    Bye
    Nov 1, 2012 1:31 PM UTC
    Posted on November 01, 2012 at 14:31
    Aren't these 16 x 2 displays prevalent on dozens of IAR / Olimex dev boards? There are surely examples within the IAR examples, or board files.
    joesoftware
    Nov 1, 2012 8:25 PM UTC
    Posted on November 01, 2012 at 21:25
    The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6m1&d=%2Fa%2F0X0000000bv3%2F8bRt.RjLTFS7vukHvN.egDef6fMU3_ExAIw8uirxxQQ&asPdf=false
    Nov 1, 2012 11:03 PM UTC
    Posted on November 02, 2012 at 00:03
    LCD_D_ALL does not appear to be consistent with your pin usage.
    Things that will cause issues are the use of the wrong pins, or timing delays which are insufficient. Make sure your timing loops are adequate, use a scope if necessary.
    Provide details of your pin usage, and the supplies to your panel.
    joesoftware
    Nov 2, 2012 7:53 AM UTC
    Posted on November 02, 2012 at 08:53
    I have not changed
    LCD_ALL
    because I use
    a
    4 bit
    configuration
    , and these
    pins
    should not be used,
    as
    RW
    I
    also
    connected to ground
    directly
    on the board.
    VSS 1 GND
    VDD 2 +5V
    VO 3 10k  Potentiometer
    RS 4 Pin 15 PORTA B
    RW 5 GND
    Enable 6 Pin 14 PORTA B
    D0 7 Not needed for 4-Bit
    D1 8 Not needed for 4-Bit
    D2 9 Not needed for 4-Bit
    D3 10 Not needed for 4-Bit
    D4 11 Pin 10 PORTA B
    D5 12 Pin 11 PORTA B
    D6 13 Pin 12 PORTA B
    D7 14 Pin 13 PORTA B
    I think it might
    be a
    timing problem
    as you said.
    joesoftware
    Nov 2, 2012 8:19 AM UTC
    Posted on November 02, 2012 at 09:19
    ok i understand the problem, my board is stm32vldiscovery at 24MHZ clock, but this code is for STM32F103RBT6 that is a 72Mhz, i need to optimize timer, but
    I hope to be
    good enough to do this.
    Nov 2, 2012 8:58 AM UTC
    Posted on November 02, 2012 at 09:58
    I have not changed
    LCD_ALL
    because I use
    a
    4 bit
    configuration
    , and these
    pins
    should not be used
    No, actually I think they're pretty critical to the operation of the code.
    #define LCD_D_ALL  (LCD_D4 | LCD_D5 | LCD_D6 | LCD_D7)
    joesoftware
    Nov 2, 2012 9:25 AM UTC
    Posted on November 02, 2012 at 10:25
    From old code that i used as starter point there are in this configuration
    /* Connections between LCD and STM32F103RB  */
    #define LCD_RS          GPIO_Pin_12  // PC12
    #define LCD_RW          GPIO_Pin_11  // PC11
    #define LCD_EN          GPIO_Pin_10  // PC10
    #define LCD_D4          GPIO_Pin_3   // PC3
    #define LCD_D5          GPIO_Pin_2   // PC2
    #define LCD_D6   GPIO_Pin_1   // PC1
    #define LCD_D7          GPIO_Pin_0   // PC0
    #define LCD_PORT        GPIOC        // Port that is connected the LCD (current port is PORT C)
    #define LCD_D_ALL  (GPIO_Pin_3 | GPIO_Pin_2 | GPIO_Pin_1 | GPIO_Pin_0)
    They are 4 more pin for use that display in full 8bit mode (DB0|DB1|DB2|DB3)
    However, I
    tried editing
    you suggested
    but
    it does not work
    I need i think a new rcc configuration and a new delay function, from 24MHZ and not from 72MHZ
    joesoftware
    Nov 2, 2012 9:55 AM UTC
    Posted on November 02, 2012 at 10:55
    i tryed this change
    //   System clocks configuration.
    void RCC_Configuration(void)
        RCC_DeInit ();                        /* RCC system reset(for debug purpose)*/
        RCC_HSEConfig (RCC_HSE_ON);           /* Enable HSE                         */
        /* Wait till HSE is ready                                                   */
        while (RCC_GetFlagStatus(RCC_FLAG_HSERDY) == RESET);
        RCC_HCLKConfig   (RCC_SYSCLK_Div1);   /* HCLK   = SYSCLK                    */
        RCC_PCLK2Config  (RCC_HCLK_Div1);     /* PCLK2  = HCLK                      */
        RCC_PCLK1Config  (RCC_HCLK_Div2);     /* PCLK1  = HCLK/2                    */
        RCC_ADCCLKConfig (RCC_PCLK2_Div4);    /* ADCCLK = PCLK2/4                   */
        *(vu32 *)0x40022000 = 0x01;           /* Flash 2 wait state                 */
        /* PLLCLK = 8MHz * 3 = 24 MHz                                               */
        RCC_PLLConfig (RCC_PLLSource_PREDIV1, RCC_PLLMul_3);
        RCC_PLLCmd (ENABLE);                  /* Enable PLL                         */
        /* Wait till PLL is ready                                                   */
        while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
        /* Select PLL as system clock source                                        */
        RCC_SYSCLKConfig (RCC_SYSCLKSource_PLLCLK);
        /* Wait till PLL is used as system clock source                             */
        while (RCC_GetSYSCLKSource() != 0x08);
    void delay_ms(int ms)
     long i, tms;
     tms = 3000*ms;
     for(i=0;i<tms;i++);
    void delay_us(int us)
     long i, tus;
     tus = 3*us;
     for(i=0;i<tus;i++);
    } Now i havent black first line, the display seems to be on but nothing appear on the screen, someone have an idea?
