Andrew Neil
Posted on November 05, 2010 at 23:39
Yes - it is pretty daft, isn't it?!
If you look carefully at the left of this photo, you can see that I adopted exactly the solution as you:
http://www.facebook.com/!/photo.php?fbid=163183327040308&set=a.1627518604167356107434509281857&pid=406728&id=107434509281857
Here's a close-up:
datac99
November 12, 2010
Posted on November 12, 2010 at 07:16
Not what I would call ''protoboard friendly'' for sure... But it wouldn't really be a big deal to lop the P3 pins off since they are not going to be mating anyway.
Just a thought :)
Andrew Neil
Posted on November 12, 2010 at 08:08
Still a pain if you actually wanted to use those pins...
Yes, the easiest ''fix'' for ST (without re-spinning the board) would be to simply not fit those pins.
