MVele.1
Oct 26, 2026 11:50 AM UTC
STM32U575/585 Reference Manual in markdown format
is it possible to get markdown format of the Reference Manual instead of the PDF version? I do not mean the converted PDF into markdown by MarkItDown or Panda, etc. These tools usually fail when the huge document is processed. They cannot keep the formatting.
Why I need it? I want to generate list of typos, misleading information, statements, etc. that should normally be fixed by ST but probably the documentary department is out of the tokens :).
E.g. in the sentence in the ADC4 chapter:
the end of sequence (EOCSEQ) occurs once the sequence of oversampled
completed (i.e. after N x sequence length conversions total)
I spent time searching for EOCSEQ flag to detect that there is no such a flag and to discover that people writing chapter 34.4.26 were not the same as those writing 34.7 to unify the names  EOCSEQ = EOS.
Cheers,
Martin
waclawek.jan
waclawek.janBest answer
Nov 3, 2026 6:02 PM UTC
The ‘C5 or the freshly released ‘G5 DS/RM *are* available in markdown. Not the ‘U5, though, as of now.
Maybe the older ones will be reprocessed, too; most likely not those ST considers “mature”.
Andrew Neil
Oct 26, 2026 12:07 PM UTC
I think you’d need to request that direct from ST - not something that the community can help you with.
Either raise a support case: https://ols.st.com/s/
Or contact your local ST office: https://www.st.com/content/st_com/en/contact-us.html
waclawek.jan
