MSeme.1
STM32L4R9 DSI with ST7797
  • June 24, 2023
  • 1 reply
  • 786 views
I need some initialization code for STM32L4R9 to drive a DSI display (1.2 rounded) 1 line. I cannot find any reference online on how to drive this kind of display. I also have initialization DSI frame from display manufacturer but I cannot make DSI work.
If I measure with oscilloscope pins CLK_P and CLK_N, the lines are fixed to HIGH. So I think DSI is not working at all.
Is there available a sample working project that uses pins 75 (Data 0)-76 (Data0) -78(clock)-79(clock)?
Thanks,
Marco.
MM..1
You write nothink about your code, then two ways:
simpler try TouchGFX example project for L4R9 and correct display set
second clean new project in IDE MX and setup right all peripherals.
LTDC DSI ...
