Tech world
Mar 8, 2018 7:20 AM UTC
STM32L475 Timestamp
Posted on March 08, 2018 at 08:20
I'm developing an application based on STM32L475 device. So I need a timestamp on my application. I saw an RTC_timestamp example of NUCLEO-L476RG. So please anyone can tell how can I port this RTC_timestamp example of NUCLEO-L476RG to my STM32L475.
Best regards.
    Andrew Neil
    Mar 8, 2018 9:24 AM UTC
    Posted on March 08, 2018 at 10:24
    What, exactly, do you mean by 'timestamp' ?
    If it just needs to be a number that increments at regular intervals, you could just use a simple timer - SysTick ?
    how can I port this
    same way that you'd port any other code:
    1. Understand the dependencies on the
      L476RG
    2. See if these are the same on
      STM32L475 - if they are, job done!
    3. If not, then update to match the
      STM32L475
    Or simply work from scratch - using the RTC can't be that hard, can it ... ?
    Tech world
    Mar 8, 2018 10:25 AM UTC
    Posted on March 08, 2018 at 11:25
    thank you, Andrew Neil for the answer.
    A timestamp is a record of time and date.
    In my case, I get the sensor values continuously but I need a timestamp.So that I understand my sensors behaviour on a different day, time.
    But I need a date and time for every corresponding value. I hope now you understand my question.
    Andrew Neil
    Mar 8, 2018 11:51 AM UTC
    Posted on March 08, 2018 at 11:51
    Not necessarily.
    But you don't need to store the actual calendar date and wall-clock time to do that.
    As noted, a simple count that increments at a known, regular interval would be sufficient.
    In fact, if your sensor is being sampled
    at a known, regular interval - then you don't need anything extra at all!
