It doesn't have an internal crystal, only an RC based oscillator/pulse generator. Voltage and Temperature will effect, temperature might also effect power supply and other external circuitry.
Design also lacks any way to pull the frequency based on temperature.
Consider a TCXO, that should at least be able to compensate itself.
