KAsim
May 26, 2019 12:37 PM UTC
STM32L412C8 USART2 RX TX pin swap not working
I am using the STM32L412C8 and I am having trouble with the USART2 RX/TX pin swapping. I enabled it in CubeMX but if I send data to the PA2 pin (originally TX but should be RX after the swap) I get nothing. If however I send my data to PA3(should be TX after the swap) data instantly comes in. Checking the CR2 register of the USART, the SWAP bit is set.
What am I doing wrong?
DOsbo
Mar 31, 2020 7:47 AM UTC
I have the same problem with an STM32F030RC.  The UART has been configured with the Swap bit enabled (verified), but I get nothing on the new Tx line.  Disabling the Swap bit allows data to be sent on the original Tx line. I'd like to know if anyone has got Tx/Rx swapping working?
