Feb 12, 2024 6:49 AM UTC
STM32L412 Issue with ADC
I'm finding difficult to get the value from the channel that i configured of a regular channel with stm32l412 microcontroller. where I'm not getting the EOC interrupt enabled in ADC_ISR register.
and When I tried to get data from ADC_CDR register, it throwing error on me like there no like this register is exists.
Really not understood why is happening like this.
Please help me in this.
Feb 12, 2024 1:16 PM UTC
Show the error.
Typically you read from the ADCx_DR register for a single ADC.
Lots of examples in CubeMX on how to use the ADC.
Aj_123Author
Feb 14, 2024 11:19 AM UTC
Please have a look into this. I'm trying to enable both regular and injected in ADC_CCR register so, we have to read from ADC_CDR regiser. Your help will be greatly appreciated. RM_CDR.png
Billy OWEN
Feb 13, 2024 6:22 PM UTC
Hi @Aj_123
The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
Regards,
Billy
AScha.3
Feb 13, 2024 6:40 PM UTC
How did you try ?
ADC_CDR is 32 bits and has two parts...
Aj_123Author
Feb 14, 2024 11:10 AM UTC
Aj_123Author
Feb 14, 2024 11:15 AM UTC
This is how i tried but, i don't know why it's happening. I have not even seen CDR register is there in registers list. Please acknowledge and respond. Your help will be greatly appreciated.
Feb 14, 2024 2:58 PM UTC
Aj_123Author
Feb 14, 2024 3:05 PM UTC
could you give me an example of this logic to read data from it .
Feb 14, 2024 3:12 PM UTC
I don't know that it has the data you want, but here is how you would read the two fields in the register:
uint32_t cdr = ADC12_COMMON->CDR;
uint16_t upper_field = cdr >> 16;
uint16_t lower_field = cdr & 0xFFFF;
