Scott Dev
Senior
Jan 31, 2017 6:02 PM UTC
STM32L0x clock
Posted on January 31, 2017 at 19:02
Hi
  I am new to the STM32L0x processor, and have moved from a freescale 8 bit controller. The first thing I am looking at is the system clock. I have a few questions hopefully someone can help? Many Thanks
I understand the 2 external oscillators, HSE and LSE. I am planning to design low power applications, and not sure if I have picked this up correctly, as only used to 1 system clock:
  1. If I use an extarnal 32.768Kz external crytal for the LSE, I see it can be used for the RTC, can this be used as a clock for the UART, and timer channels?
  2. If I do number 1., do i use an internal clock for the SYSCLK?
Many Thanks
Scott
    Nesrine M_O
    Nesrine M_OBest answer
    Feb 1, 2017 10:02 AM UTC
    Posted on February 01, 2017 at 11:02
    Hi
    devlin.scott
    Welcome to STM32 community
    As it is said by
    Waclawek.Jan
    , you have first to refer to Reset and clock control(RCC) chapter in your related reference manual (Clock tree).
    As newbie with STM32 family,I recommend you to download the
    http://www.st.com/content/st_com/en/products/development-tools/software-development-tools/stm32-software-development-tools/stm32-configurators-and-code-generators/stm32cubemx.html
    which is a graphical software configuration tool that allows generating C initialization code using graphical wizards.( refer
    http://www.st.com/content/ccc/resource/technical/document/user_manual/10/c5/1a/43/3a/70/43/7d/DM001047pdf/files/DM001047pdf/jcr:content/translations/en.DM001047pdf
    User manual for further details about CUBEMX)
    -Nesrine-
    waclawek.jan
    Jan 31, 2017 6:36 PM UTC
    Posted on January 31, 2017 at 19:36
    In the RM (which depends on the exact part number), there is a whole-page clock schematics in the RCC chapter.
    The answer to your questions is probably no (at least not directly, you may be able to condition the HSI by LSE using a timer and software), but I don't use the 'L0s so it's up to you to figure out the details.
    Nesrine M_O
    Hi
    devlin.scott
    As it is said by
    Waclawek.Jan
    -Nesrine-
    Scott Dev
    Scott DevAuthor
    Senior
    Feb 2, 2017 1:40 PM UTC
    Posted on February 02, 2017 at 13:40
    Thanks for the reply
