Chris Oh
Mar 9, 2018 4:13 AM UTC
STM32L073 + sx1272 (downlink rssi)
Posted on March 09, 2018 at 05:13
I'm using LoRa network with sx1272 + stm32L0 (node),
and RAK831 (gateway) , also custom network server.
i found that uplink rssi printed in gateway is quite good enough(-32dBm), however, downlink rssi printed in node(stm32L0) is quite bad(-90dBm).
the distance from each other is same, and i use SF 12 & same channel.
the power level gateway use is 23dBm which is the standard of Korea.
I don't know why this difference happens.
is this problem maybe from end node's hardware issue or sx1272's bad sensitivity?  or gateway emitting low-quality signal (maybe it's not).
    Mar 9, 2018 5:45 AM UTC
    Posted on March 09, 2018 at 06:45
    Then perhaps you need to establish some baseline using some different nodes/implementations? Say with SX1272 or SX1276 shields, or Murata module on a LoRa Discovery board. Or look at implementations with an LNA on the receive side.
    Andrew Neil
    Mar 9, 2018 8:48 AM UTC
    Posted on March 09, 2018 at 08:48
    Agreed.
    Can you try a different gateway?
