LMehm
Feb 15, 2019 12:12 PM UTC
STM32L0 strange behaviour.
Hello!
I have some strange behavior with STM32L0 processor.
I get Hard fault error in my function and I can't understand why this happens?!
I have equivalent codes - one of them works and other doesn't work causing Hard fault error.
Also this happens only when function is called with parameter mCopy=2.
I use SystemWorkbench for STM32 IDE.
I have attached these two codes - working and problematic code.
Would you please help me!
Thank you!
    Tesla DeLoreanBest answer
    Feb 15, 2019 1:51 PM UTC
    The trick here is to look at what the processor is complaining about. The Hard Fault points to the faulting instructions and has register content.
    The CM0 doesn't like unaligned 32-bit reads, ie (addr & 3) != 0
    LMehm
    LMehmAuthor
    Feb 16, 2019 7:26 AM UTC
    Thank you, Clive!
    I will check it!
    LMehm
    LMehmAuthor
    Feb 18, 2019 7:54 AM UTC
    Problem is solved!
    Thank you, Clive!
