chrkaras
Feb 16, 2026 3:09 PM UTC
STM32H755 FIFO DMA
Hello everyone!
I got the following problem; I need to read from two 32bit addresses and write the data to three. Specifically, i am interested in the case shown in the left side of the image, where the N[0:15] increment by half word and write to the M[0:15] but it will increment by a full word. Don't worry about the reserved bytes in the HTIMx_CC1R, I checked the manual and are always at zero.
I saw that the H7 can read/write with weird patters using the fifo functionality. The thing is I can't understand at all how to set it up. Is there any other better way?
Thanks in advance!
FBLBest answer
Sep 23, 2026 2:04 PM UTC
Hi ​@chrkaras
It’s not recommended to rely on DMA FIFO for this custom repacking. You can use software packing, or you can evaluate MDMA for non contiguous blocks.
FBLBest answer
Hi ​@chrkaras
chrkaras
chrkarasAuthor
Oct 6, 2026 9:48 PM UTC
Hello ​@FBL,
I did not have to use such a case in the end. I will close the issue.
