STM32H747 Discovery - DMA not starting
I tried to translate my 32F746 Discovery Audio program (SAI with DMA DB Mode) to the STM32H747 Discovery Board (using the M7). SAI and DMA are correct configured. I am not able to start DMA1 Stream 0 or to set the S0CR EN Bit manually. SAI is started (SAIXEN and DMAEN of SAI1A are set) . What am I doing wrong ?
regards
Dave
