KNaim.1
Stm32h743ii serie with QSPI memory W25Q256JV
Hello all
Hardware
stm32h743iitx
flash : W25Q256JV
sdRam: w9825g6kh
lcd : 7 pouces no driver 24bit parrallel
I have dev a stm32h743ii pcb with a 7 pouces 24 bit lcd . the basic debug work for the lcd and sdram
Where i am facing problem is on flash W25Q256JV qspi work fine just with 1 line but impossible to make working bank 1 with 4 lines.
Can i have some confirmation with the community about :
if someone has experiment something please share i going crasy ........
KDJEM.1
Hello @KNaim.1;
What do you mean by "impossible to make working bank 1 with 4 lines."?
Is it possible to read the device ID?
Are you having problems reading or writing?
Can you share the command instructions configuration?
Thank you.
Kaouthar
