September 3, 2024
STM32H743 RTC Clock configuration failure
I'm working on STM32H743BIT6, It is in production phase. During flashing the software, it is failed to configure LSE crystal with internal RTC enabled. out of 50 boards 2 board got failed.
During debug it is observed that the RTC clock configuration is getting failed.
Kindly support us for resolving the issue
Thank You
Anil Gayakwad
mƎALLEm
Not sure what do you mean by "During flashing the software, it is failed to configure LSE crystal with internal RTC enabled". ?
Do you mean that the RTC failed to be configured at your application startup? and what is the symptom? enable to write to a register or what?
