Visitor
Nov 25, 2026 18:36 UTC
STM32H7 HSE oscillator drive level
I’m trying to figure out what crystal I can use on my STM32H753. I’ve checked the datasheet and AN2867 (with the help of AI) to figure out what crystals I could use. Then I used the crystal selection tool from ECS and ended up with the ECS-250-8-36-RWN-TR, which (according to ECS), supports the H7, whatever that means. I think I’ve figured most things out, the only concerning point is the drive level. The crystal specifies a maximum of 100uW and I can’t figure out how to match that to the H7. Everything I find seems to suggest to just add a 0R resistor and then to measure and adjust that resistor. I don’t have the tools with the required precision (and probably lack the skill to measure this correctly). Is there really no better way to do this? How much of an issue would it be if I’m above 100uW?
AScha.3
Nov 25, 2026 19:10 UTC
the ECSxxx is a standard crystal and should work fine; just find the best matching loading caps, about 10PF i would start.
And the 0,0001 W wont cause an explosion or do anything else you can see - just it might not oscillate under all conditions (maybe at -40° C it gets problems...).
Or do it “my way” : just use a crystal oscillator and forget any problems with loading caps, crystal power, temperature, etc..
Just set the HSE to bypass and connect an oscillator , and if you want do it perfect: add a series damping resistor, maybe 50 ohms, to avoid ringing.
And its not any more expensive , example: -at mouser-
Nov 25, 2026 19:59 UTC
Useful links:
Let’s assume a typical peak-to-peak voltage on the crystal of about 1Vpp, then we can use the formula given in section 3.5.2 of the design guide:
  • Drive Level = ( ESR * (π * F * C_tot)^2 * Vpp^2 ) / 2
  • C_tot = C_load1 + (C_stray / 2)
To get Cload1 (which is the same as Cload2), you will need to calculate the required load capacitors for your circuit:
  • C_load_effective = ( (C_load1 * C_load2) / (C_load1 + C_load2) ) + C_stray
  • C_stray is the PCB parasitic capacitance in the oscillator circuit. It can be estimated at about 3pF for a reasonably good layout
Your crystal wants C_load_effective to be 8pF, which is the total capacitance seen by the crystal. Solving for your load capacitors give you C_load1 = C_load2 = 10pF
Now it’s easy to solve for the drive level:
  • Crystal ESR = 60Ω
  • Crystal Freq = 25MHz
  • Vpp = 1V, but for fun let’s use 2V as a worst case value
  • C_stray is estimated as 3pF
  • C_load1 = C_load2 = 10pF
  • C_tot = 10pF + 3pF / 2 = 11.5pF
  • Max Drive Level = (60Ω * (π * 25MHz * 11.5pF)^2 * (2V)^2) / 2 = 98µW
So, if you assume a worst case Vpp of 2V on your crystal, then you will stay under 100µW. Something like Vpp = 800mV would be more typical, which give you about 16µW. Crystal manufacturer know what they are doing and design for a very wide array of applications. Just remember to set up your MCU for a ceramic crystal, not an external oscillator in bypass mode.
