HDesa.1
STM32H7 dual core: FreeRTOS & Timer selection for each core
I am using STM32H7 dual core series. Currently I am planning to enable FreeRTOS in M4 core and let M7 core run in regular fashion.
As FreeRTOS uses SysTick, I have given M4 core on of the controller timer. Is there any need to also give M7 core a different timer? As M7 core is not running FreeRTOS, can it continue running on SysTick timer.
-Regards
mƎALLEm
mƎALLEmBest answer
Each core has its own system tick timer. Each core has its own program to run and using systick or not on CM7 doesn't change anything in your scenario.
https://developer.arm.com/Processors/Cortex-M4
https://developer.arm.com/Processors/Cortex-M7
mƎALLEm
mƎALLEmBest answer
HDesa.1
HDesa.1Author
Thank you for the clarification.
This means I can definitely run one core in a loop & other core using FreeRTOS, right?
Also if I need to communicate between the cores then I can still use Openamp middleware.
-Regards
-RegardsHrishikesh
mƎALLEm
