VYoun
STM32H7 AT24CM02 EEPROM
  • June 23, 2020
  • 4 replies
  • 1028 views
I am trying to integrate an AT24CM02 into my project.
Can anyone suggest any libraries compatible with HAL?
your help is much appreciated.
Thank you and best regards,
Vouria
June 23, 2020
The I2C ones?
HAL_I2C_Mem_Read()
HAL_I2C_Mem_Write()
You're likely going to need to code your own routines for the memory itself, data sheet should give details on byte/page writes
VYoun
VYounAuthor
Yes I mean the I2C one.
Thank you very much for your answer. It is very helpful. I will check right now.
Best regards,
Vouria
First hit on Google for “at24cm02 hal library�?:
https://github.com/sinadarvi/SD_HAL_AT24
probably need to adapt it, but might be a good start.
VYoun
VYounAuthor
Thank you for your answer, I have indeed downloaded this code, but so far have not been able to make it work.
I will try again.
Best regards,
Vouria
