Dec 9, 2024 8:14 AM UTC
STM32H563 Debug mode stopped working
While debugging STM32H5 SPI2 (slave and master) in receive mode, the debug suddenly stopped and somehow I can't work in debug again.
redsireBest answer
Dec 12, 2024 5:08 AM UTC
I tried another debugger (J-Link) and it worked, then I tried connecting with ST-Link V2 again and it worked too.
Thanks to everyone who tried to help.
Andrew Neil
Dec 9, 2024 9:27 AM UTC
You're going to need to give a lot more detail for anyone to be able to help!
See the Posting Tips:
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
What debugger (software & hardware) were you using?
What is your target hardware?
What, exactly, were you doing before it "stopped"?
What, exactly, happened?  Were there error messages? Was there smoke?
So what, exactly, does happen when you try to debug?
Can you debug any other target(s)? Can you load other firmware?
Have you reset and/or power-cycled the target before trying again?
Ozone
Principal
Dec 9, 2024 9:50 AM UTC
Correct.
"Doesn't work anymore" contains nothing to really work with.
I would suspect a core lock-up, due to a faulty exception handler.
redsireAuthorBest answer
Ozone
Principal
Dec 13, 2024 8:03 AM UTC
Some (or most) SWD/JTAG debug pods have the capability to supply power to the debuggee.
Check this option is not enabled, unless you really want to use it.
