May 20, 2024
STM32G491 Pin1 Marking
Hey, i
got this STM32G491MET6
The datasheet does not really help here to identify pin 1, since there are 4 markings to see. Anyone has a clue on this? In the previous revision of this datasheet, Pin 1 is bottom left . Already burnt 2 mcus because of this...
May 20, 2024
Smaller circle, bottom left. The others are molding / ejector related.
ST prints the text in top-to-bottom, left-to-right western form. Held in a readable fashion the Pin 1 designation is down and to the left.
May 20, 2024
My expectation is that legitimate parts will have a common VSS bonding, which you could continuity check to confirm orientation expectations.
Could perhaps look for other boards, orientation, where VCC and GND enter, HSE placed, SWDIO/SWCLK and VCAPs (where used)
waclawek.jan
This appears to be a regression in rev4 of the DS:
@Imen.D, can you please have a look at this? Thanks.
Hi @waclawek.jan,
All device markings are being removed from the Datasheet and are being moved to the Technical note: Reference device marking schematics for STM32 microcontrollers and microprocessors.
May 23, 2024
Someone should also have a word with the graphics dept.. about unhelpful imagery
waclawek.jan
Hi @Imen.D ,
Okay, and is/will be there a link/pointer to that document in the datasheets themselves, or is it upon us to spread the gospel?
Thanks,
Jan
Muhammed Güler
Senior III
May 23, 2024
On most ICs, the bottom row of the label contains the first pin.
May 23, 2024
Which is great advice until it's not..
You should have a conversation with my pick-n-place guy some day..
Muhammed Güler
Senior III
May 23, 2024
I've never encountered an IC labeled like this before. Until you showed me this picture, I believed there was a standard for IC naming that I didn't know about.
