STM32G474 HRTIMER ADC Trigger
I'm trying to configure the ADC to read to values at a specific time in my system that uses the STM32G474.
I have two channels of peak current mode control using the HRTIMER. The outputs are reset from either a comparator event or max duty cycle compare value on each channel.
For each channel, I want to sample a voltage at a fixed delay time after the output is reset.
Any help is greatly appreciated.
Thank you
