thomas23
Feb 20, 2021 4:06 PM UTC
STM32G473 I2C2 pinout mistake in Datasheet
I would like to make a new electronic design with the STM32G473, using I2C2.
But it seems there is a mistake in the datasheet regarding the pinout.
On pin description it says:
PA8 = I2C2 SDA
PA9 = I2C2 CLK
PA10 = I2C2 SMBA
Whereas on Alternate function it says:
PA8 = I2C2 SMBA
PA9 = I2C2 CLK
PA10 = I2C2 SDA
Which one is correct?
If I look on other similar MCUs, I think the second version (Alternate function) is correct, but if I check on CubeMX, it says the same as on pin description.
Thanks for your help!
Imen GH
Imen GHBest answer
Feb 23, 2021 11:47 AM UTC
​ Hello @thomas23​ ,
The pin description is the correct one:
PA8 = I2C2 SDA
PA10 = I2C2 SMBA
I will report the error to our team for correction.
Thanks for your contribution
Imen
Imen GH
Feb 22, 2021 8:22 AM UTC
​Hello @thomas23​,
I will check and get back to you
Imen
thomas23
thomas23Author
Feb 22, 2021 7:03 PM UTC
Ok thanks!
Imen GH
Imen GHBest answer
PA8 = I2C2 SDA
PA10 = I2C2 SMBA
Imen
margce
Jul 26, 2022 4:40 AM UTC
This is still an issue even on the latest DS12712 rev4 datasheet available to download. Please be aware!
DOCon.1
Senior
Feb 8, 2023 11:28 AM UTC
Just got bitten by this; request User Manual update please.
KDJEM.1
Apr 24, 2023 9:16 AM UTC
This issue is fixed and the new Datasheet revision is published in the ST website: DS12712 Rev 5.
Thank you.
Kaouthar
