STM32G431RB Internal Temperature Sensor
I am working on the STM32G431RB Nucleo board, specifically on the internal temperature sensor. I am facing issues in getting accurate readings.
For your reference, I have attached:
  • My code implementation
  • An Excel sheet comparing temperature readings with respect to a thermal chamber
The sensor readings are not matching the expected values. Could you please guide me on the correct way to use this sensor and help identify any corrections required in my implementation?
/* USER CODE END Header */
#include "main.h"
/* USER CODE END Includes */
/* USER CODE BEGIN PTD */
uint16_t adc_val,ref_adc,ts_ref,ts_cal1,ts_cal2;
float vdd,temp,vdd,avg_temp;
float alpha =0.075;
#define TS_CAL1 ((uint16_t * ) 0x1FFF75A8)
#define TS_CAL2 ((uint16_t * ) 0x1FFF75Ca)
#define ref_val ((uint16_t * ) 0x1FFF75aa)
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
/* USER CODE END PM */
ADC_HandleTypeDef hadc1;
DMA_HandleTypeDef hdma_adc1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
static void MX_DMA_Init(void);
static void MX_ADC1_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
 * @brief The application entry point.
 * @retval int
int main(void)
 /* USER CODE BEGIN 1 */
 /* USER CODE END 1 */
 HAL_Init();
 /* USER CODE BEGIN Init */
 /* USER CODE END Init */
 SystemClock_Config();
 /* USER CODE BEGIN SysInit */
 /* USER CODE END SysInit */
 MX_GPIO_Init();
 MX_DMA_Init();
 MX_ADC1_Init();
 /* USER CODE BEGIN 2 */
 /* USER CODE END 2 */
 /* Infinite loop */
 /* USER CODE BEGIN WHILE */
 while (1)
 /* USER CODE END WHILE */
 /* USER CODE BEGIN 3 */
	 HAL_ADC_Start(&hadc1);
	 HAL_ADC_PollForConversion(&hadc1, 10);
	 adc_val=HAL_ADC_GetValue(&hadc1);
	 ref_adc=HAL_ADC_GetValue(&hadc1);
	 HAL_ADC_Stop(&hadc1);
	 //-------------------vdd calculation
		 ts_ref=*ref_val;
 		 ts_cal1=*TS_CAL1;
 		 ts_cal2=*TS_CAL2;
	 vdd=((float)(ts_ref*3.0f)/(float)ref_adc);
	 temp = ((float)(adc_val*(vdd/3.0f)-ts_cal1))*(110.0f-30.0f)/((float)(ts_cal2-ts_cal1))+30.0f;
	 avg_temp=alpha*temp+(1.0f-alpha)*avg_temp;
 /* USER CODE END 3 */
 * @retval None
void SystemClock_Config(void)
 HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1_BOOST);
 RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
 RCC_OscInitStruct.HSIState = RCC_HSI_ON;
 RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
 RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
 RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV4;
 RCC_OscInitStruct.PLL.PLLN = 85;
 RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
 RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
 RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
 Error_Handler();
 RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
 RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
 if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
 Error_Handler();
 * @brief ADC1 Initialization Function
 * None
 * @retval None
 /* USER CODE BEGIN ADC1_Init 0 */
 /* USER CODE END ADC1_Init 0 */
 ADC_MultiModeTypeDef multimode = {0};
 ADC_ChannelConfTypeDef sConfig = {0};
 /* USER CODE BEGIN ADC1_Init 1 */
 /* USER CODE END ADC1_Init 1 */
 /** Common config
 hadc1.Instance = ADC1;
 hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4;
 hadc1.Init.Resolution = ADC_RESOLUTION_12B;
 hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
 hadc1.Init.GainCompensation = 0;
 hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;
 hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
 hadc1.Init.LowPowerAutoWait = DISABLE;
 hadc1.Init.ContinuousConvMode = ENABLE;
 hadc1.Init.NbrOfConversion = 2;
 hadc1.Init.DiscontinuousConvMode = DISABLE;
 hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
 hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
 hadc1.Init.DMAContinuousRequests = ENABLE;
 hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED;
 hadc1.Init.OversamplingMode = DISABLE;
 if (HAL_ADC_Init(&hadc1) != HAL_OK)
 Error_Handler();
 /** Configure the ADC multi-mode
 multimode.Mode = ADC_MODE_INDEPENDENT;
 if (HAL_ADCEx_MultiModeConfigChannel(&hadc1, &multimode) != HAL_OK)
 Error_Handler();
 /** Configure Regular Channel
 sConfig.Channel = ADC_CHANNEL_TEMPSENSOR_ADC1;
 sConfig.Rank = ADC_REGULAR_RANK_1;
 sConfig.SamplingTime = ADC_SAMPLETIME_640CYCLES_5;
 sConfig.SingleDiff = ADC_SINGLE_ENDED;
 sConfig.OffsetNumber = ADC_OFFSET_NONE;
 sConfig.Offset = 0;
 if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
 Error_Handler();
 sConfig.Channel = ADC_CHANNEL_VREFINT;
 sConfig.Rank = ADC_REGULAR_RANK_2;
 Error_Handler();
 /* USER CODE BEGIN ADC1_Init 2 */
 /* USER CODE END ADC1_Init 2 */
 * Enable DMA controller clock
 /* DMA controller clock enable */
 __HAL_RCC_DMAMUX1_CLK_ENABLE();
 __HAL_RCC_DMA1_CLK_ENABLE();
 /* DMA interrupt init */
 /* DMA1_Channel1_IRQn interrupt configuration */
 HAL_NVIC_SetPriority(DMA1_Channel1_IRQn, 0, 0);
 HAL_NVIC_EnableIRQ(DMA1_Channel1_IRQn);
 * None
 * @retval None
 /* USER CODE BEGIN MX_GPIO_Init_1 */
 /* USER CODE END MX_GPIO_Init_1 */
 /* GPIO Ports Clock Enable */
 __HAL_RCC_GPIOC_CLK_ENABLE();
 __HAL_RCC_GPIOA_CLK_ENABLE();
 /* USER CODE BEGIN MX_GPIO_Init_2 */
 /* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
 * @brief This function is executed in case of error occurrence.
 * @retval None
void Error_Handler(void)
 __disable_irq();
 while (1)
#ifdef USE_FULL_ASSERT
 * @brief Reports the name of the source file and the source line number
 * where the assert_param error has occurred.
 * file: pointer to the source file name
 * line: assert_param error line source number
 * @retval None
void assert_failed(uint8_t *file, uint32_t line)
 /* USER CODE BEGIN 6 */
 /* User can add his own implementation to report the file name and line number,
 ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
 /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
RobK1
RobK1Best answer
I would say your expectations are a bit high.
waclawek.jan
Do you perform ADC calibration as the first thing before performing the first conversion?
Other than that, here is a checklist.
ok i will try this one and share the results.
There must be a call to calibrate it before using. CubeMX adds it for most families but it looks like it's missing here.
if (HAL_ADCEx_Calibration_Start(&hadc1, ADC_SINGLE_ENDED) != HAL_OK)
 STM32CubeG4/Projects/NUCLEO-G431RB/Examples/ADC/ADC_GainCompensation/Src/main.c at 7b3187393c6be722cd92ab596a83a61303698ffb · STMicroelectronics/STM32CubeG4
As per you're
/* USER CODE BEGIN Header */
 * @file : main.c
 * @brief : Main program body
 * @attention
 * Copyright (c) 2025 STMicroelectronics.
 * All rights reserved.
#include "main.h"
float alpha =0.075;
 * @retval int
int main(void)
 HAL_Init();
 MX_GPIO_Init();
 MX_DMA_Init();
 MX_ADC1_Init();
 if(HAL_ADCEx_Calibration_Start(&hadc1, ADC_SINGLE_ENDED)!=HAL_OK)
	 Error_Handler();
 /* Infinite loop */
 while (1)
	 if( HAL_ADC_Start(&hadc1)!=HAL_OK)
			 Error_Handler();
	 if(HAL_ADC_Stop(&hadc1) !=HAL_OK)
			 Error_Handler();
		 ts_ref=*ref_val;
 		 ts_cal1=*TS_CAL1;
 		 ts_cal2=*TS_CAL2;
 * @retval None
 Error_Handler();
 Error_Handler();
 * @PAram None
 * @retval None
 /** Common config
 Error_Handler();
 Error_Handler();
 sConfig.Offset = 0;
 Error_Handler();
 Error_Handler();
 * @PAram None
 * @retval None
 * @retval None
 __disable_irq();
 while (1)
 * @PAram file: pointer to the source file name
 * @PAram line: assert_param error line source number
 * @retval None
suggestion i implement my code with
this command  but still i am not getting proper results. Here i attach the readings please check once and share you're view.
RobK1
RobK1Best answer
So you’re saying there is an error of ±5 °C, right?
RobK1
I'm saying there is a lot of room for error and that you should not expect the internal temperature sensor to be a precision device.
Also, the datasheet says TS_CAL2 is acquired at 130°C, but your code uses 110.
Okay, but can we at least expect linearity in temperature measurement?
RobK1
The graph you posted seems pretty linear to me. You have a slope and an offset error, surely. Have you actually corrected your code for the high temperature calibration value?
I wouldn't expect chamber temperature and internal temperature to match exactly. The chamber is ambient and the internal temp is the junction temperature. The board will take a while to come to steady state and the internal temperature will also be higher (at steady state) than ambient.
If you fix the 130 vs 110 error as @RobK1 notes, see if values are more consistent with expectations. Junction should be a little higher than ambient. Amount depends on how much energy it's using.
In my experience, typical accuracy is within a few degrees C.
This is acceptable, but we at least expect linear behavior, which is not observed. A temperature offset or difference is understandable, but the lack of linearity is concerning.
From my observations:
  • At 25 °C, the STM reports 29.25 °C
  • At 35 °C, it reports 36.68 °C
  • At 65 °C, it reports 59.80 °C
This seems to contradict your explanation. Additionally, the response time of the internal temperature sensor is quite slow, which is very unexpected from such a powerful controller.
How long are you waiting before taking these readings? If the chip is embedded within a device, it can take a significant (up to ~2 hours) for the chip to reach steady state.
Perhaps post the full graph of ambient temp and junction temp over the course of the entire experiment.
The power of the controller doesn't affect the 2nd law of thermodynamics. Heat behaves the same regardless of device speed.
Did you fix the error in your previously posted code?
1. check this value in stm32g4xx_ll_adc. or corresponding file
#define VREFINT_CAL_VREF ( 3300U) /* Analog voltage reference (Vref+) value with which temperature sensor has been calibrated in production (tolerance: +-10 mV) (unit: mV). */
Since you are using 3V as Vref i am not sure if that's correct. It is usually 3.3 V
2. use these macros available in your stm32g4xx_ll_adc.h
for vref:
#define __LL_ADC_CALC_DATA_TO_VOLTAGE(__VREFANALOG_VOLTAGE__,\
__ADC_DATA__,\
__ADC_RESOLUTION__) \
((__ADC_DATA__) * (__VREFANALOG_VOLTAGE__) \
/ __LL_ADC_DIGITAL_SCALE(__ADC_RESOLUTION__) \
#define __LL_ADC_CALC_TEMPERATURE(__VREFANALOG_VOLTAGE__,\
__TEMPSENSOR_ADC_DATA__,\
(((( ((int32_t)((__LL_ADC_CONVERT_DATA_RESOLUTION((__TEMPSENSOR_ADC_DATA__), \
(__ADC_RESOLUTION__), \
LL_ADC_RESOLUTION_12B) \
* (__VREFANALOG_VOLTAGE__)) \
/ TEMPSENSOR_CAL_VREFANALOG) \
- (int32_t) *TEMPSENSOR_CAL1_ADDR) \
) * (int32_t)(TEMPSENSOR_CAL2_TEMP - TEMPSENSOR_CAL1_TEMP) \
) / (int32_t)((int32_t)*TEMPSENSOR_CAL2_ADDR - (int32_t)*TEMPSENSOR_CAL1_ADDR) \
) + TEMPSENSOR_CAL1_TEMP \
and calibrate adc using : HAL_ADCEx_Calibration_Start (&hadc)
3.
As mentioned earlier, the internal temperature sensor does not measure the ambient chamber temperature; it measures the junction temperature of the microcontroller’s silicon die. Since the die naturally runs hotter than the surrounding environment, the internal reading will always be higher than the chamber temperature.
If you need to measure the actual chamber temperature, you’ll need an external temperature sensor (e.g., via I2C or another interface). Because you are comparing two different quantities (junction vs. ambient temperature), the percentage error you calculated is not valid.
As per your suggestions, I have tried all the recommended options:
  1. I first tested with a 3.3V reference voltage, but I did not observe any significant changes.
  2. Following your second suggestion, I used the lower-level command  but this resulted in highly unexpected values.
  3. Regarding your third point, I partly agree with the statement: "The internal temperature sensor does not measure the ambient chamber temperature; it measures the junction temperature of the microcontroller’s silicon die." I also understand that using an external temperature sensor would be the more reliable approach.
However, I would like to highlight an interesting observation. At 25 °C, the STM reports 29.25 °C; at 35 °C, it reports 36.68 °C; and at 65 °C, it reports 59.80 °C. This seems to contradict the statement "Since the die naturally runs hotter than the surrounding environment, the internal reading will always be higher than the chamber temperature."
In fact, based on my measurements, as the chamber temperature increases, the reported STM temperature tends to fall below the actual value. This suggests that the slope is not correct, which may be due to an issue in my code or potentially a hardware-related limitation of the MCU.
I would appreciate your opinion on this matter.
