omid hamdi
stm32g431 timer encoder mode master slave
any one can help me how to used 2 pcs 16bit timer for make one 32bit on encoder mode
need one example for setup timer
waclawek.jan
You can't. Encoder changes DIR (direction of counting), and that is not propagated through the TRGO-TRGI mechanism to other timer.
So either use 32-bit timer, or do it software - sample the timer regularly and count over/underflows.
