June 17, 2024
STM32G070RB reference design; L1 inductor on AVDD
We are using STM32G070RB for our application. Need a reference design for the schematic & also as mentioned in below screenshot there is requirement of L1 inductor on AVDD pin, Please let me know the Required value of inductance/impedance or please suggest suitable part no.
Also can we connect VBAT to VDD?
waclawek.jan
Review AN5096.
There's no AVDD pin on this mcu, and VDDA is internally connected to VDD.
You may be talking about VREF+; if you want to supply that from VDD/VDDA, basically you want to create a low-pass filter to filter out all the digital noise; but there is no single good design/value/model/make for it. You may have a look at the related 'G0 DISCO/EVAL board how is this detail solved there.
Andrew Neil
Although the Disco boards are not necessarily optimised for best analogue performance ...
