Jul 28, 2024 21:15 UTC
STM32G030F6P6 TSSOP20 crystal oscillator?
As I understand, the TSSOP20 version needs an external oscillator instead of a 8MHz crystal connected directly to the MCU pins. Is that correct?
I'm asking because I have seen a board on AliExpress using this same processor with a 8MHz crystal.
TDKBest answer
Jul 28, 2024 21:35 UTC
Correct, the TSSOP20 doesn't have an OSC_OUT which means it can't be hooked up to a crystal directly.
No clue what's going on with that board. Schematic doesn't seem available. Probably the crystal is not very useful on it.
TDKBest answer
BarryWhit
Lead
Jul 29, 2024 04:39 UTC
Very curious. a schematic (could be typical AE misinfo) is available but shows no crystal
https://nl.aliexpress.com/item/1005005574646465.html
There's also a Baidu (Chinese Cloud drive) download link at the top of that page for a zip file of assets for that board, but it seems to be china only.
On at least one unrelated project, someone thought it was a good idea to connect a 16Mhz crystal to OSC32, I wonder if that's a clever hack or a *** mistake: hack.https://github.com/brunohoplite/stm32g030f6p6_evaluation_board/blob/master/PCB/Schematic_stm32g0f0_eval.pdf
Update: really?!? the word *** is censored? that's so ***ing ***. What a bunch of ***.
"- If someone's post helped resolve your issue, please thank them by clicking ""Accept as Solution"".- Please post an update with details once you've solved your issue. Your experience may help others."
May 23, 2026 11:25 UTC
Definitely a mistake ... Don't ask me how I know ^^
RomainR.
May 23, 2026 16:08 UTC
The TSSOP20 versions of the STM32G0 only support an external HSE bypass oscillator on PC14 (OSC_IN), but they can also use a LSE crystal on PC14–PC15 as the SYSCLK source.
I would be curious to understand the purpose of this 8 MHz crystal on this STM32G030F6 board. I could not find any schematic for this board. Very strange !
If I were to use this kind of hardware, for a lower price and with slightly better PCB manufacturing quality, I would rather use this instead, especially since the schematics are available online:
https://github.com/WeActStudio/WeActStudio.STM32G0xxC0xxCoreBoard/tree/master
Otherwise, here our official reference hardware, which is fully documented and supported by our ecosystem.
https://www.st.com/en/evaluation-tools/nucleo-g031k8.html
Best regards,
Romain,
