MTora.1
stm32g030 External crystal pin map
Hi everyone
I use STM32G030. I'm gonna set the clock system to HSE on the External crystal, but I couldn't find the proper RCC_OCS_OUT.
What are the MCU's crystal correct pins?
Please help me set the correct pinout.
Thank you
mƎALLEm
mƎALLEmBest answer
Hello @MTora.1 ,
You need a crystal oscillator (XO) not a crystal (XTAL) as OSC_OUT is not available in this MCU part number.
Please refer to this article:
Do you know when to use a crystal or an oscillator?
This chip does not have an OSC_OUT pin and cannot use a crystal. Only bypass mode is available.
The LQFP48 package has this pin. Others do not.
MTora.1
MTora.1Author
I use LQFP32.
I see that. That is why I said this chip does not have the OSC_OUT pin available.
mƎALLEm
mƎALLEmBest answer
Hello @MTora.1 ,
