Jun 20, 2025 10:27 AM UTC
STM32F7xx: How to read DBGMCU_IDCODE from bootloader?
Hi;
In order to determine exactly the chip type I'd like to read the DBGMCU_IDCODE register. When I try to do this the bootloader hangs. RM0410 44.6.1 says "Only 32 bit access support". I guess the bootloader uses byte access.
Is there a workaround?
Reading UID and FLASHSIZE works just fine.
Andrew Neil
Jun 20, 2025 10:28 AM UTC
Which bootloader are you referring to?
Jun 20, 2025 10:51 AM UTC
the internal ROM bootloader
Andrew Neil
Jun 20, 2025 11:16 AM UTC
But that's fixed code, which you can't modify - so how does you reading DBGMCU_IDCODE relate to that?
Perhaps you show a minimum but complete example which illustrates the issue.
How to insert source code.
