Avan.7
Aug 14, 2018 11:34 AM UTC
STM32f746G - Discovery - Audio Pins
Hi
I am having issues with playing sound through the audio out jack. I have gone through the BSP examples but what's lacking for me is the correct setup of the pins.
At the moment I have set up -
SAI2 Block A (Master) - (I2S/PCM enabled)
I2C3
I2S3
DMA for SAI2 Block A
Am I missing anything with regards to the correct initialization in regards to getting audio to play out through my speakers?
Any help would be much appreciated.
    Imen.DBest answer
    Aug 14, 2018 12:18 PM UTC
    You can start with the audio example available in the STM32CubeF7, it will help you on your configuration: STM32Cube_FW_F7_V1.12.0\Projects\STM32746G-Discovery\Applications\Audio\Audio_playback_and_record and you find more details on how to use it in the readme.txt file.
    You should follow the STM32F746xx datasheet and UM1907 for your assignments for each pin.
    With Regards,
    Imen
    Imen.DBest answer
    With Regards,
    Imen
