stm32f746disc sdmmc with fatfs make problem while read or open file in 4 bit mode
Posted on March 06, 2017 at 04:26
I use fatfs to read text file line by line every time
when i use normal sdmcc driver which initialize sd wide mode to 4 B i got fault errors randomly and fatfs hang or stuck at hal sd_getscr function
so i have to change driver setting to 1B mode
I searched too much but couldnot find the problem solution
