Riccardo Franceschetto
Jun 1, 2023 10:05 AM UTC
[STM32F469] Using HAL_SPI_TransmitReceive not writing on the receive buffer.
I implemented a simple spi transmission on a STM32F469 based board.
The problem i'm facing is that the spi function I'm not getting any value in the receive buffer.
Trough the oscilloscope i can see the byte being send and the one transmitted back from slave device, i'm using a gpio as chip select because notoriusly the hardware NSS by hal does not work properly.
What could be the problem?
Here's my code., the function names might differ because of internal implementation, but are HAL based.
Init Function:
void SIN_SPI6_Init(SPI_HandleTypeDef* spiP)
 spiP ->Instance = SPI6;
 spiP ->Init.Mode = SPI_MODE_MASTER;
 spiP ->Init.Direction = SPI_DIRECTION_2LINES;
 spiP ->Init.DataSize = SPI_DATASIZE_8BIT;
 spiP ->Init.CLKPolarity = SPI_POLARITY_LOW;
 spiP ->Init.CLKPhase = SPI_PHASE_1EDGE;
 spiP ->Init.NSS = SPI_NSS_SOFT;
 spiP ->Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_256;
 spiP ->Init.FirstBit = SPI_FIRSTBIT_MSB;
 spiP ->Init.TIMode = SPI_TIMODE_DISABLE;
 spiP ->Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
 spiP ->Init.CRCPolynomial = 10;
 if (HAL_SPI_Init(spiP) != HAL_OK)
 Error_Handler(2);
MSP function:
void HAL_SPI_MspInit(SPI_HandleTypeDef* hspi)
 if(hspi->Instance==SPI2)
 /* Peripheral clock enable */
 __HAL_RCC_SPI2_CLK_ENABLE();
 __HAL_RCC_GPIOB_CLK_ENABLE();
 __HAL_RCC_GPIOC_CLK_ENABLE();
 /**SPI2 GPIO Configuration
 PB13 ------> SPI2_SCK
 PC3 ------> SPI2_MOSI
 PC2 ------> SPI2_MISO
 GPIO_InitStruct.Pin = GPIO_PIN_13;
 GPIO_InitStruct.Alternate = GPIO_AF5_SPI2;
 GPIO_InitStruct.Pin = GPIO_PIN_3|GPIO_PIN_2;
 HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
 else if(hspi->Instance==SPI6)
 /* USER CODE BEGIN SPI6_MspInit 0 */
 /* USER CODE END SPI6_MspInit 0 */
 __HAL_RCC_SPI6_CLK_ENABLE();
 __HAL_RCC_GPIOG_CLK_ENABLE();
 /**SPI6 GPIO Configuration
 PG14 ------> SPI6_MOSI
 PG13 ------> SPI6_SCK
 PG12 ------> SPI6_MISO
 GPIO_InitStruct.Pin = GPIO_PIN_14|GPIO_PIN_13|GPIO_PIN_12;
 GPIO_InitStruct.Alternate = GPIO_AF5_SPI6;
 HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
The code to the transmission:
HAL_GPIO_WritePin(GPIOB, GPIO_PIN_11, GPIO_PIN_RESET); //SPI6_NSS low
 uint8_t readStatusRegister = 0b00000101;
 uint8_t readback = 0;
 if (HAL_SPI_TransmitReceive (&hspi6, &readStatusRegister,&readback,2, 10) != HAL_OK)
 Error_Handler(6);
 HAL_GPIO_WritePin(GPIOB, GPIO_PIN_11, GPIO_PIN_SET); //SPI6_NSS high
waclawek.jan
Jun 2, 2023 7:11 AM UTC
If you initialize the receive buffer to some particular (non-zero, non-FF) value, does it change?
Did you check directly on the mcu pin? Think bad solder joints or shorts.
Jun 10, 2023 8:32 AM UTC
I cant check on the mcu pins because its a bga package.
But i checked on the nearest contact i can put a probe.
S.Ma
Principal
Jun 10, 2023 1:53 PM UTC
You can probably probe the 4 SPI signals with a multimeter/oscilloscope, go in debug mode, stop the code, view and modify the GPIO registers to confirm the copper lanes are the right ones.
gbm
Jun 2, 2023 7:46 AM UTC
You are writing 2 bytes from a 1-byte buffer, then reading 2 bytes into another 1-byte buffer. There might be more errors like these in the rest of your code.
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
Jun 10, 2023 8:31 AM UTC
Sorry, but isn't the total number of bytes that needs to be specified? The number of bytes to transmit+receive.
Piranha
Principal III
Jun 10, 2023 1:00 PM UTC
No, and that would be ridiculous even for ST's broken bloatware. It took me few seconds to find it out by looking at the code... Less than writing this short post!
S.Ma
Principal
Jun 10, 2023 1:57 PM UTC
Local variables are sometime optimized to be only core registers which don't have memory address location. They are also not volatile, DMA for example can't access them. At least make them volatile to be sure.
 uint8_t readStatusRegister = 0b00000101; ==> Make them global to exist as memory address and not a register. Make them volatile type
 uint8_t readback = 0; ==> Same thing.
 Error_Handler(6);
gbm
Jun 12, 2023 11:57 AM UTC
Wrong. No need for volatile specifier at all. If the data address is referenced, the compiler must implement the data in memory.
