d146
June 27, 2019
STM32F446RE: why ADC output has and offset by 300 mV for various analog input?
I'm working on STM nucleo board (STM32F446RE) currently.I'm using ADC Channel 0 and 1.I have found that the ADC output has and offset by 300 mV for various analog input. Please explain the cause.
/* code snippet to read ADC Channel 1 output*/
for( int i=0; i<SIZE; i++)
adc2[i] = TM_ADC_Read(ADC1, ADC_Channel_1);
waclawek.jan
How do you calculate the voltage from ADC readout? What is the input source, is it low impedance enough/is the sampling time long enough?
Ozone
Principal
June 27, 2019
ADCs are inputs.
Most probably, this offset exist already at the inputs, from your hardware.
Or, as Jan suggested, your sampling time is much too short.
