liangbing119
stm32f439i LCD(800*600) display run in 16bit sdram
  • March 21, 2016
  • 576 views
Posted on March 21, 2016 at 10:56
sdram clock run in 90MHz;LCD clock run in 24MHz.it not work(display ng).but LCD clock run in 18MHz,it work(display ok),but it looks blink,because reflesh rate low.
huw to solve it?
    Radosław
    Posted on March 21, 2016 at 13:19
    800*600*4 *25 =  48MB/s
    16bit SDRAM  90MHz  -> ~150MB/s.  Simply math.  Only for read.  Quite big bandwith LCD uses.
    liangbing119
    Posted on March 22, 2016 at 02:33
    Yes,I think so.But LCD clock run in 18MHz(18M/800/600=37.5),less than 37 frames(true 18M/1000/660=27 frames,it looks blink),LCD bandwith 18M*24bit=54MB/s,I want 50 frames/s,LCD clock will set in 33MHz(bandwith 800*600*3*50 = 72MB/s).But LCD clock run in 20M,display unreadable code.
    How to solve it?
