kadir ustun1
Mar 29, 2018 10:41 AM UTC
STM32F429 CAN2 Receive
Posted on March 29, 2018 at 12:41
Hello, I have a problem. when I use CAN1, I can receive data, but when ı use CAN2, I can not receive. why ?
    Szymon PANECKI
    Senior III
    Mar 29, 2018 10:52 AM UTC
    Posted on March 29, 2018 at 12:52
    Hello Kadir,
    Two ideas come to my mind.
    One reason of your issue could be wrong confuguration of CAN filtering. Please refer to
    https://community.st.com/0D50X00009XkWoMSAV
    , which describes similar problem.
    Second reason is related to relationship between CAN1 and CAN2. They share some common resources, which are managed by CAN1 always. As a result in order to use CAN2, at least clock for CAN1 has to be enabled. Please make sure that your code calls a function for CAN1 clock enabling.
    Szymon
    kadir ustun1
    Mar 29, 2018 1:13 PM UTC
    Posted on March 29, 2018 at 13:13
    thank you for explain. at project, ı use CAN2 only.
