STM32F411RE using External power supply
to finish my project i want to remove my the cable wich is plugged in to my PC. So i need an external power supply. In the Datasheet i found the topic "external power supply" but i still dont know how to connect it. It says that i have to use E5V or VIN. I was searching for a electric circuit but without success. Also i dont know is which accumulator i should use. Are there any recommendations you can give me, for buying and accumulator? I only have a bluetooth device on my USART1 plugged in nothing else.
