HSarı.1
STM32F407VGTX_FLASH.ld: No such file or directory error
Hi i wanted to try new extension but i get this error. The code is a basic blink its working on cubeide but when i try on vscode this happens.
Thank you already
[build] c:\st\stm32cubeide_1.10.1\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.10.3-2021.10.win32_1.0.0.202111181127\tools\arm-none-eabi\bin\ld.exe: cannot open linker script file C:/newcodes/ledblink/STM32F407VGTX_FLASH.ld: No such file or directory
[build] collect2.exe: error: ld returned 1 exit status
Hi @Hüseyin Avni Sarıkaya​
Did you check that the path is valid? Or, if the file is missing, you can try to copy it from the original project.
HSarı.1
HSarı.1Author
Yeah path is valid and file is missing but i didnt try copiying it is linker files project spesific or its global for that mcu?
Nawres GHARBI
could you try a shorter path please without special characters
