Elliott Li
Jul 25, 2017 4:04 PM UTC
STM32F407VG discovery kit read multiple encoder
Posted on July 25, 2017 at 18:04
Hi all,
I am try to use
STM32F407VG discovery kit to read 5 encoder. I use TIM_HandleTypeDef and TIM_Encoder_InitTypeDef lib to read one encoder successfully. When I use the same code to read two encoders, I found that it doesn't work. Do anyone know that can I use this lib to read multiple encoder? Do anyone have any example code.
Thank you.
    Vangelis Fortounas
    Jul 26, 2017 9:24 AM UTC
    Posted on July 26, 2017 at 11:24
    Hello!
    The encoders use TIM1, TIM2, TIM3, TIM4, TIM5 timers to work.
    Every timer is separate inialised as encoder.
    So when you want to use each one encoder , must call the same function ofcourse  with the appropriate previously initialised TIM_HandleTypeDef as  parameter!
    TIM_HandleTypeDef htim1, htim2...;// at global scope
    //inside your funtion (main or other)
    enci;//
    //fill the structures wiith proper data
    htim1.Instance = TIM1;
    enci.EncoderMode = TIM_ENCODERMODE_TI1;
    HAL_TIM_Encoder_Init(&htim1,  &enci);//initialisation..
    htim2.Instance = TIM2;
    HAL_TIM_Encoder_Init(&htim2,  &enci);//initialisation..
    //after initialisation , start all encoders
    HAL_TIM_Encoder_Start(&htim1, TIM_CHANNEL_1) ;//start each encoder
    HAL_TIM_Encoder_Start(&htim2, TIM_CHANNEL_1) ;
    waclawek.jan
    Jul 26, 2017 9:09 AM UTC
    Posted on July 26, 2017 at 11:09
    Post details.
    Note that not all timers support the encoder mode.
    Vangelis Fortounas
    Hello!
    enci;//
    Elliott Li
    Jul 26, 2017 3:55 PM UTC
    Posted on July 26, 2017 at 15:55
    Thank you
