Andrew Neil
Welcome to the forum.
For people to be able to help, you need to give more details - see How to write your question to maximize your chances to find a solution
Remember that we know absolutely nothing about you or your project other than what you provide in your post.
PS:
Does it work if you use USART6 without DMA ?
xt_itAuthor
if I don't use USART6'DMA ,I can write to SD card normally. But,if I use the USART's DMA ,When I write to SD,it will loss many data
Andrew Neil
Just to be clear: It does work when you use USART6 - just so long as you don't use DMA with it?
Are you using DMA with the SDIO ?
January 21, 2025
What does this mean? It trashes the file system on the card making it unreadable or just corrupts the file contents of what you are logging?
Do they share resources or channels? I don't recollect there being a problem on this platform.
Debug the issue.
xt_itAuthor
just loss data in sd card
